I have been having trouble getting the oven to turn on and stay on. If I don't hear a "click" then it turns off in about 30 seconds. So I might have to turn the oven on 6 times before it stays on. Once it is on then the temperature is accurate and steady so I didn't think it had anything to do with a thermostat. Is this an ignitor problem? Also have one burner on the stove top that if I sure that burner the ignitor will not stop "clicking". Do the two have anything to do with each other??
I'm afraid I did not get it clear. Can you describe step by step what is going on after you set the temperature and pushed the Bake button?
When I press the "bake" button the digital display comes up and I can set my desired temp but in about 30-45 seconds it turns off. I repeat this as many as 6-8 times and finally when you set the desired temp I will hear a click and the oven "thumps" and I know it has turned on this time. It then operates normally. I hope this is a better explaination of what it does.
Sounds like the control board (aka an Electronic Oven Control) is bad. - The part number for the EOC is AP2632694 Gene.
