Wasann
#1 Posted : Monday, December 22, 2008 9:10:43 AM(UTC)
Wasann
I have been having trouble getting the oven to turn on and stay on. If I don't hear a "click" then it turns off in about 30 seconds. So I might have to turn the oven on 6 times before it stays on. Once it is on then the temperature is accurate and steady so I didn't think it had anything to do with a thermostat. Is this an ignitor problem? Also have one burner on the stove top that if I sure that burner the ignitor will not stop "clicking". Do the two have anything to do with each other??
#2 Posted : Monday, December 22, 2008 6:23:38 PM(UTC)
I'm afraid I did not get it clear. Can you describe step by step what is going on after you set the temperature and pushed the Bake button?
Wasann
#3 Posted : Tuesday, December 23, 2008 4:45:17 AM(UTC)
Wasann
When I press the "bake" button the digital display comes up and I can set my desired temp but in about 30-45 seconds it turns off. I repeat this as many as 6-8 times and finally when you set the desired temp I will hear a click and the oven "thumps" and I know it has turned on this time. It then operates normally. I hope this is a better explaination of what it does.
#4 Posted : Wednesday, December 24, 2008 10:32:08 PM(UTC)
Sounds like the control board (aka an Electronic Oven Control) is bad.
- The part number for the EOC is AP2632694
Frigidaire wall oven model CGEB30S8CS1 oven will not turn on (Oven Repair (including Ranges and Cooktops))
by RHykawy 4/2/2021 2:00:36 PM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
Frigidaire Gallary Electric Range Oven Will Not Turn On (Oven Repair (including Ranges and Cooktops))
by jaycevs 12/2/2014 5:28:35 AM(UTC)
Jenn-air double wall oven - lower oven will not turn on (Oven Repair (including Ranges and Cooktops))
by hjustice 9/28/2014 11:37:55 AM(UTC)
GAs range oven will not turn on (Oven Repair (including Ranges and Cooktops))
by JohnRogers 4/18/2013 8:21:57 AM(UTC)
Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by Bkomperda 2/6/2013 2:59:00 PM(UTC)
Maytag oven will not turn on (Oven Repair (including Ranges and Cooktops))
by threeputt 12/10/2012 12:07:16 PM(UTC)
Need to bake/ oven will not turn on! (Oven Repair (including Ranges and Cooktops))
by ms michelle 1/24/2011 3:05:15 PM(UTC)
Oven Will not Turn On (Oven Repair (including Ranges and Cooktops))
by pete8960 3/25/2010 7:47:46 AM(UTC)
Frigadiare Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by 29264 3/17/2010 10:58:24 AM(UTC)
by mcarp 9/25/2009 3:28:57 PM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
by rortega 7/11/2009 9:15:43 AM(UTC)
by CTHEESFELD 7/10/2009 6:30:11 AM(UTC)
Oven will not turn on, broiler works, stove top works (Oven Repair (including Ranges and Cooktops))
by caewart 6/19/2009 4:31:43 PM(UTC)
