i need a wiring diagram for a maytag washing machine model #la512
Unfortunately there is no on-line information available for this very old model. What is the original problem?
the washer will stop in the middle of washing and will not do anything, i believe it is the overload on the motor, the motor might need replacing. it will start running after about 15 minutes.
Most likely the problem is a bad motor. Remove the front panel and check the belts and check if the motor got hot when it stops. The part number for the motor is AP3720974 Here are the break down diagrams for the Maytag washer Model LA512Gene.
