shotgun58
#1 Posted : Monday, December 22, 2008 8:23:05 AM(UTC)
shotgun58
i need a wiring diagram for a maytag washing machine model #la512
#2 Posted : Monday, December 22, 2008 6:17:03 PM(UTC)
Unfortunately there is no on-line information available for this very old model. What is the original problem?
shotgun58
#3 Posted : Tuesday, December 23, 2008 5:07:34 AM(UTC)
shotgun58
the washer will stop in the middle of washing and will not do anything, i believe it is the overload on the motor, the motor might need replacing. it will start running after about 15 minutes.
#4 Posted : Thursday, December 25, 2008 11:53:30 AM(UTC)
Most likely the problem is a bad motor. Remove the front panel and check the belts and check if the motor got hot when it stops.
The part number for the motor is AP3720974
Here are the break down diagrams for the Maytag washer Model LA512
