One of the drawer touchpads is no longer working. The high temp on/off toggle works fine but the cycle selector is stuck on quick clean. Is there a repair possible or should I just replace the touchpad? If so where is it in the parts list? I read the parts diagram several times and couldn't find it.
Thanks, John
Hello John, did you try unplugging it, letting it sit for a couple of minutes ? I had the same issue and doing this reset it and it worked. Derek
Hmmm, Nice simple idea. I will try it!
