Lone Beagle
#1 Posted : Sunday, February 27, 2011 1:09:29 PM(UTC)
Lone Beagle
One of the drawer touchpads is no longer working. The high temp on/off toggle works fine but the cycle selector is stuck on quick clean. Is there a repair possible or should I just replace the touchpad? If so where is it in the parts list? I read the parts diagram several times and couldn't find it.
Thanks,
John
DMCFixes
#2 Posted : Friday, June 10, 2011 12:51:28 PM(UTC)
DMCFixes
Hello John, did you try unplugging it, letting it sit for a couple of minutes ? I had the same issue and doing this reset it and it worked. Derek
Lone Beagle
#3 Posted : Friday, June 10, 2011 1:55:13 PM(UTC)
Lone Beagle
Hmmm, Nice simple idea. I will try it!
