kwmnh
#1 Posted : Friday, February 25, 2011 11:48:19 PM(UTC)
kwmnh
opened it, shocks looks ok to me.
any suggestions ?
Thanks,
Leo
#2 Posted : Saturday, February 26, 2011 12:27:46 AM(UTC)
Is this washer a top loader, or front loader, model # shows a top loader.
kwmnh
#3 Posted : Saturday, February 26, 2011 8:19:54 AM(UTC)
kwmnh
its the top loader kenmore laundry center, and the drier is on top of it,
#4 Posted : Saturday, February 26, 2011 11:44:36 AM(UTC)
You probably have a disconnected stabilizer spring in the back that wore through the frame, will need to drill a new hole.
kwmnh
#5 Posted : Saturday, February 26, 2011 12:57:04 PM(UTC)
kwmnh
i opened it again, check the spring, its attached well.
i left the front panel off and watched through the whole cycle.
when it started spinning and doing the banging noise, i sprayed wd40 in the center metal piece that spin under the drum, and the noise is gone now....:)
thoughts ?
#6 Posted : Saturday, February 26, 2011 3:12:38 PM(UTC)
I am not familiar with this suspension, only think you had a stuck brake shoe, but I can't see any on the suspension view.
