The washer will not agitate in wash cycle. It fills, spins during rinse and pumps OK. The belts are intact. I blew the fuse while attempting to manually manipulate the lid switch to see when the spindle was turning, I am on my way out to get a new fuse.
What's next to troubleshoot?
Does the motor run during the agitation?
No, the only sound appears to be the control knob timer.
geostan
Most likely the problem is a bad motor. Perform the troubleshooting as described in the Service manual (page 4-8). Here are the break down diagrams for the Maytag washer Model LAT3914AAEGene.
Gene, Thanks for the follow-up. I noticed that each time I cycled the timer knob, it did not operate consistently. The motor never operated during the wash cycle, but it operated during spin, most of the time. I decided to replace the timer assembly and the washer works like new. Thanks again, Geostan
Whirlpool LA5700XTN0 won't agitate
(Washer Repair)
by Kyou
6/2/2024 5:13:20 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise
(Washer Repair)
by deepdiver359
5/21/2024 8:09:21 PM(UTC)
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin
(Washer Repair)
by Guest
5/13/2023 11:34:56 AM(UTC)
Maytag washer spins but won't agitate
(Washer Repair)
by salconflu
4/27/2022 6:06:43 PM(UTC)
maytag washer mvwc465hw3 won't agitate
(Washer Repair)
by Guest
11/22/2021 2:54:31 PM(UTC)
Washer won't agitate or spin out.
(Washer Repair)
by tracibailey
1/11/2019 8:43:20 AM(UTC)
Washer won't agitate, spin, drain, but motor runs
(Washer Repair)
by dmbailey0321
6/26/2018 11:36:55 AM(UTC)
LAT2500AAE will spin,rinse,and drain but won't agitate
(Washer Repair)
by jlh72
1/18/2018 5:39:10 PM(UTC)
Kitchen Aid Washer Won't agitate or spin
(Washer Repair)
by M Yaworski
7/18/2017 7:00:37 AM(UTC)
Washing machine won't agitate, will spin though
(Washer Repair)
by Freddy76
7/17/2017 4:05:56 PM(UTC)
Kenmore 110-92573200 won't agitate, but spins and advances
(Washer Repair)
by LallyCollins
3/5/2017 9:44:00 AM(UTC)
Whirlpool Washer Won't Agitate/Spin
(Washer Repair)
by Shazaam
9/1/2016 2:47:46 PM(UTC)
Whrilpool Cabrio won't agitate
(Washer Repair)
by Harvey E.
7/27/2016 11:58:40 AM(UTC)
GE Washer fills & drains, but won't agitate or spin
(Washer Repair)
by bonerjamz03
1/10/2016 6:17:17 PM(UTC)
Washing machine won't agitate, drain, etc.
(Washer Repair)
by rhinkley
12/17/2015 2:44:46 AM(UTC)
