captsx1
#1 Posted : Friday, December 19, 2008 10:38:57 AM(UTC)
captsx1
I just got home from a weeks vacation, to find my Fridge/Freeser was warm inside. I could here something running, which i presume was the fan.
I have moved it away from the wall and removed the cover off the back to see if i can detect a symptom. The fan is running, which is blowing/pulling air away from the compressor.
I disconneded the fan, as it was making noise and i couldn't here the compressor. I switched the fridge back on, and heard and audible click like a contactor making. I could then here a faint hum, like an electric motor trying to start but couldn't. After a short while, there was another click and the hum went away.
Does this mean i have a bad compressor, or does it have sometype of starting circuit that may have gone south? If the compressor is bad, what is a better option, replace the compressor or the whole fridge (from a cost stand point).
Steve
captsx1
#2 Posted : Friday, December 19, 2008 11:00:32 AM(UTC)
captsx1
In addition, I have removed, what i presume is the starter and overload. When i shake the starter (the overload remained on the compessor) it rattles (though contactors sometimes do) and black dust/grit falls out. Could this indicate a bad starter?
Steve
#3 Posted : Saturday, December 20, 2008 3:17:22 AM(UTC)
Yes
Here is a good link, check out #3
http://www.applianceaid.com/refrigerator.html
Here is the link to your parts and a tech sheet
Model Search
https://www.servicematters.com/d...0Sheet%20-%202204338.pdf
captsx1
#4 Posted : Sunday, December 21, 2008 6:34:09 AM(UTC)
captsx1
Replaced the Starter part and the Fridge/Freezer is working fine.
Thank-you Denman!
Steve
Is my refrigerator compressor bad? (Refrigerator & Freezer Repair)
by master_of_universe 8/17/2020 6:53:56 PM(UTC)
Frigidaire refrigerator compressor bad? (Refrigerator & Freezer Repair)
by herky1991 9/1/2019 8:22:23 AM(UTC)
fridge - compressor bad? (Refrigerator & Freezer Repair)
by bratzcpa 12/25/2012 7:28:29 PM(UTC)
Compressor Bad? (Refrigerator & Freezer Repair)
by dgbt688 2/3/2010 9:51:23 AM(UTC)
