nelsonflint
#1 Posted : Friday, December 19, 2008 10:18:16 AM(UTC)
nelsonflint
I am trying to replace the door glasses in a Kitchenaid oven that were removed by someone else.
1. I have two clips (ref 23 on the schematic, part no. 4451432). They have two elongated holes that appear to be screw holes. Where (specifically) do they go?
2. The top corners of the middle glass piece (of three) slides under the tabs in the Glass Retainer (ref 5, part no. 8300778). Does the third piece of glass lay right over the middle piece. If so, what hold it's top corners in place?
:confused:
#2 Posted : Friday, December 19, 2008 4:00:03 PM(UTC)
You can find the complete instructions in the Service manual.
Here are the break down diagrams for the Kitchen Aid oven Model KEMC308KSS01
Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by Amsel7 11/29/2013 7:26:50 AM(UTC)
Outer Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ksouthar 11/15/2012 6:40:58 PM(UTC)
Kitchenaid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by drill 1/6/2012 5:48:30 AM(UTC)
KitchenAid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by gglbox 3/8/2010 6:18:55 PM(UTC)
oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by Eggman 10/14/2009 1:37:50 PM(UTC)
Microwave Door Glass Replacement (Microwave Repair)
by Johne. 7/12/2009 7:16:42 PM(UTC)
door glass replacement (Microwave Repair)
by williape 3/12/2009 2:14:13 PM(UTC)
Oven Door Glass Replacement - Help! (Oven Repair (including Ranges and Cooktops))
by VWC318 11/21/2008 2:04:56 PM(UTC)
Oven Door Glass Replacement Question (Oven Repair (including Ranges and Cooktops))
by ckrobins 2/21/2008 3:19:21 PM(UTC)
Oven door glass replacement (Oven Repair (including Ranges and Cooktops))
by rondelaney 1/20/2008 5:50:19 AM(UTC)
Gas Range Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ronkat 11/16/2007 3:08:54 PM(UTC)
