hi
I think i have a bad igniter .. everything works but the oven,,the broil part also works....how do i remove the lower igniter??....do i remove the back?..is it connected to a cb?....and i was wondering if i can swap them b4 i order to be sure that is the issue,,,,thank you,,,,you guys are the best the part # i came up wth is ap2014008
