rpeters23
#1 Posted : Tuesday, February 22, 2011 5:17:07 PM(UTC)
rpeters23
I put my oven to preheat for 350 degrees, but for some reason it wouldn't heat further then 140 degrees.
I did some research and come to find out it's possible the bottom element.
Then today my wife stated the stove top burner weren't working, she had to put them on high for them to burn; then they stop working all of sudden.
My question: is there a safty mechenism that will shut down the stove top or is it two separate issues that's i need to repair. Or is it just to deal with the lower element.
With the directions can anyone replace the lower element?
Please advise thank you!
abadfish66
#2 Posted : Tuesday, February 22, 2011 5:58:41 PM(UTC)
abadfish66
I suspect you have a power problem. Check the back of the range. Pull the range out and unplug it. pull the panel where the powere cord connects at the terminal block. look for a loose red or black connection where the plug wires screw in to.
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
by gplundell@msn.com 4/21/2015 3:33:43 PM(UTC)
by paulgbernard 2/14/2015 3:50:00 PM(UTC)
Oven NOT heating up at all (Oven Repair (including Ranges and Cooktops))
by bkevans88 10/31/2014 6:14:02 PM(UTC)
Oven not heating up right. (Oven Repair (including Ranges and Cooktops))
by clueless78 10/17/2014 2:49:30 PM(UTC)
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 3/18/2014 6:25:03 PM(UTC)
Oven not heating up (Microwave Repair)
by coldoc89 5/9/2013 7:06:35 PM(UTC)
oven not heating up (Oven Repair (including Ranges and Cooktops))
by vwforonda 8/21/2012 5:54:27 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
convection oven not heating up to correct temperature (Oven Repair (including Ranges and Cooktops))
by cecelo 1/17/2012 6:57:16 AM(UTC)
by cren722 12/20/2011 1:14:07 PM(UTC)
oven not heating up to temperature (Oven Repair (including Ranges and Cooktops))
by buhr 9/12/2011 11:43:11 AM(UTC)
by doette-56 3/6/2011 4:37:05 PM(UTC)
