mick8043
#1 Posted : Wednesday, December 17, 2008 4:27:14 PM(UTC)
mick8043
When plugged in all ignitors click. If left rear burner is on, they all stop. When any other burner is on the others continue to click. Replaced the spark module and one spark ignition switch that looked burned. Any suggestions?
#2 Posted : Thursday, December 18, 2008 1:46:01 PM(UTC)
The first thing I would check is the proper polarity (hot to hot and neutral to neutral) at the power plug and at the power cord connection to the cooktop. Make sure the cooktop is properly grounded.
If there is nothing wrong then one of the ignition switches is shorted or there is a cross wires somewhere. Disconnect all ignition switches and then reconnect them one at a time. Check all wires.
Here are the break down diagrams for the Kitchen Aid cooktop Model KGCT305XAL0
GE rangetop acting strange (Oven Repair (including Ranges and Cooktops))
by Olmski 6/7/2022 5:10:55 PM(UTC)
Viking rangetop out of control flames (Oven Repair (including Ranges and Cooktops))
by tobloyd 12/30/2017 9:47:59 AM(UTC)
Thermador rangetop blue indicator light stays on (Oven Repair (including Ranges and Cooktops))
by bivind 12/28/2014 8:01:09 PM(UTC)
Panel and Oven Not Working, Rangetop Works (Oven Repair (including Ranges and Cooktops))
by Casper777 3/19/2012 7:11:40 PM(UTC)
How to access rangetop burner elements..... (Oven Repair (including Ranges and Cooktops))
by FDAR 5/4/2011 9:29:03 AM(UTC)
Gaffers & Sattler Rangetop (Oven Repair (including Ranges and Cooktops))
by jkarabians 3/6/2011 6:23:00 AM(UTC)
Thermador Rangetop Pressure Regulator (Oven Repair (including Ranges and Cooktops))
by jtalleysc 9/21/2009 2:06:49 PM(UTC)
Inconsistent heating, Whirlpool rangetop (Oven Repair (including Ranges and Cooktops))
by pcjamison 1/18/2009 8:37:53 AM(UTC)
Replacing ceramic rangetop (Oven Repair (including Ranges and Cooktops))
by George Keeler 10/26/2008 4:11:48 PM(UTC)
Stove - Rangetop (Oven Repair (including Ranges and Cooktops))
by admit assist 5/5/2008 6:06:12 AM(UTC)
