When plugged in all ignitors click. If left rear burner is on, they all stop. When any other burner is on the others continue to click. Replaced the spark module and one spark ignition switch that looked burned. Any suggestions?
The first thing I would check is the proper polarity (hot to hot and neutral to neutral) at the power plug and at the power cord connection to the cooktop. Make sure the cooktop is properly grounded. If there is nothing wrong then one of the ignition switches is shorted or there is a cross wires somewhere. Disconnect all ignition switches and then reconnect them one at a time. Check all wires. Here are the break down diagrams for the Kitchen Aid cooktop Model KGCT305XAL0Gene.
