wooddust
#1 Posted : Monday, February 21, 2011 10:41:19 AM(UTC)
wooddust
I have just installed a new gasket on the frame of dishwasher that the door closes against. I have a problem with the ends (bottom) of the gasket. Should if be cut off at the bottom or allowed to stick out toward the door. It was fine for about a week but it leaking again at the left from corner only.
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 7:49:17 AM(UTC)
Jeff / APP Team
The gasket is fine the way it is. If it is leaking from the corners you will nees to order this kit.:) Part number: AP4338941
wooddust
#3 Posted : Tuesday, February 22, 2011 10:09:25 AM(UTC)
wooddust
The dishwashers listed for the AP4338941 are all Kenmore, mine is a Frigidaire. Is that the right part
Jeff / APP Team
#4 Posted : Tuesday, February 22, 2011 10:17:00 AM(UTC)
Jeff / APP Team
Yes this is made for all Frigidaire dishwashers built after 2005. It also works on those Kenmore models.
wooddust
#5 Posted : Tuesday, February 22, 2011 12:17:02 PM(UTC)
wooddust
I bought my diswasher in August 2004, before the 2005 date you stated.
Jeff / APP Team
#6 Posted : Tuesday, February 22, 2011 12:29:26 PM(UTC)
Jeff / APP Team
Ok at the top where age of unit is it said less than 1 year. According to your model number you gave, this is a repair kit for leaking around the door corners. The dishwasher didn't come with these on it. The extra gasket you have left is fine resting toward the door. This is a kit Frigidaire recommends for your problem to fix it.
