I have just installed a new gasket on the frame of dishwasher that the door closes against. I have a problem with the ends (bottom) of the gasket. Should if be cut off at the bottom or allowed to stick out toward the door. It was fine for about a week but it leaking again at the left from corner only.
The gasket is fine the way it is. If it is leaking from the corners you will nees to order this kit.:) Part number: AP4338941
The dishwashers listed for the AP4338941 are all Kenmore, mine is a Frigidaire. Is that the right part
Yes this is made for all Frigidaire dishwashers built after 2005. It also works on those Kenmore models.
Originally Posted by: wooddust  The dishwashers listed for the AP4338941 are all Kenmore, mine is a Frigidaire. Is that the right part I bought my diswasher in August 2004, before the 2005 date you stated.
Ok at the top where age of unit is it said less than 1 year. According to your model number you gave, this is a repair kit for leaking around the door corners. The dishwasher didn't come with these on it. The extra gasket you have left is fine resting toward the door. This is a kit Frigidaire recommends for your problem to fix it.
