k8mp
#1 Posted : Saturday, October 13, 2007 3:14:34 PM(UTC)
k8mp
I ran it with the cabinet off and used the screwdriver/stethascope test to isolate the noise. It appears to be coming from the clutch.
What are the steps to remove it?
#2 Posted : Sunday, October 14, 2007 2:49:41 AM(UTC)
Either you have a bad tranny or a stripped agitator. I would remove agitator and check splines. If ok I would pull motor and pump and turn tranny coupler counterclockwise. If you feal tranny clunking you have a bad tranny.
k8mp
#3 Posted : Monday, October 15, 2007 4:57:54 AM(UTC)
k8mp
Is it safe the lay the washer on its side when removing the motor & tranny?
#4 Posted : Monday, October 15, 2007 8:51:50 AM(UTC)
I never do this, I just tilt it back sufficiently to remove tranny, just less work.
