k8mp
#1 Posted : 17 years ago
k8mp
I ran it with the cabinet off and used the screwdriver/stethascope test to isolate the noise. It appears to be coming from the clutch.
What are the steps to remove it?
#2 Posted : 17 years ago
Either you have a bad tranny or a stripped agitator. I would remove agitator and check splines. If ok I would pull motor and pump and turn tranny coupler counterclockwise. If you feal tranny clunking you have a bad tranny.
k8mp
#3 Posted : 17 years ago
k8mp
Is it safe the lay the washer on its side when removing the motor & tranny?
#4 Posted : 17 years ago
I never do this, I just tilt it back sufficiently to remove tranny, just less work.
