al taylor
#1 Posted : Monday, December 15, 2008 3:37:14 PM(UTC)
al taylor
KitchenAid Diswasher starts as normal fills with heated water, but washarm doesn't spin. Can hear motor making a humming type noise. I hit the cancel button and it will drain and can hear pump draining. All of the water drains. Is there a shaft from washarm to motor? If anybody had same problem,please contact. Thanks Al
#2 Posted : Tuesday, December 16, 2008 3:26:34 PM(UTC)
Hi Al,
Looks like the problem is a stuck motor in the wash pump (drain pump is separate).
The first thing I would check is the chopper assembly (#6 on the break down diagram). If there is nothing wrong then the motor has to be replaced.
You can find the complete instructions in the tech sheets.
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDL01ILBS0
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Kitchen Aid Dishwasher - KUDS25SHBT1 (Dishwasher Repair)
by Karen M 10/19/2022 10:03:13 AM(UTC)
Kitchen Aid Dishwasher Upper Spray Arm (Dishwasher Repair)
by Guest 1/13/2022 12:58:02 PM(UTC)
Kitchen Aid Dishwasher KUPC10FxSS5 Di (Dishwasher Repair)
by Andrew Glass 9/27/2021 11:37:55 AM(UTC)
Kitchen aid dishwasher KUDS01FLSS5 - top rack doesn't get wet and soap residue (Dishwasher Repair)
by Joe D Raleigh 10/13/2019 3:25:49 PM(UTC)
Kitchen Aid Dishwasher Screech (Dishwasher Repair)
by mark.stacy@emc.com 11/5/2018 6:45:56 PM(UTC)
Kitchen Aid Dishwasher Blinking Lights (Dishwasher Repair)
by T/Y4HELP 8/7/2016 5:20:39 AM(UTC)
No lights on Kitchen aid dishwasher (Dishwasher Repair)
by Gschimma 12/22/2015 7:02:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
kitchen aid dishwasher drain motor will not run (Dishwasher Repair)
by phantomjet 4/22/2015 8:17:13 PM(UTC)
kitchen aid dishwasher (Dishwasher Repair)
by jacquesaccount 8/21/2014 8:15:31 AM(UTC)
Kitchen Aid dishwasher stopped working (Dishwasher Repair)
by acillatem 6/15/2014 6:12:42 PM(UTC)
Kitchen Aid dishwasher doesn't drain completely (Dishwasher Repair)
by rgjhnsn 5/31/2014 5:57:43 PM(UTC)
Kitchen Aid Dishwasher won't start (Dishwasher Repair)
by waveraider 1/30/2014 9:00:51 PM(UTC)
Kitchen Aid Dishwasher: Blinking Lights, Unfinished Cycle General Malaise (Dishwasher Repair)
by 3Zero 10/24/2013 4:57:00 PM(UTC)
