lando
#1 Posted : Monday, December 15, 2008 2:06:22 PM(UTC)
lando
Have a maytag(LAT8426AAE) washer that has developed a leak from the bottom of the tub where the tranny runs through.will the tub bearing kit resolve this?The text says i should change the seal kit at the same time. what do I need to order? The IPB says it will need a spanner wrench to remove the spanner nut>
Drags1998
#2 Posted : Monday, December 15, 2008 2:44:02 PM(UTC)
Drags1998
Change the TUB SEAL (stem&seal kit) don't worry about the TUB BEARING!!!
lando
#3 Posted : Monday, December 15, 2008 3:25:31 PM(UTC)
lando
Thanks Drags 1998
Guest (4)
Maytag Leaking water NOT clogged (Refrigerator & Freezer Repair)
by radcliff299 7/26/2015 4:11:39 PM(UTC)
Maytag leaking from bottom (Washer Repair)
by Pdvining 7/5/2013 12:08:41 PM(UTC)
Maytag leaking (Dishwasher Repair)
by jeremy1635 6/21/2012 4:01:05 PM(UTC)
Maytag Leaking at Center Shaft (Washer Repair)
by qwe 2/4/2010 12:55:38 PM(UTC)
Maytag leaking and soap not opening (Dishwasher Repair)
by spark3542 7/16/2009 3:42:37 AM(UTC)
Maytag leaking lubricant (Washer Repair)
by ddscz 5/28/2009 2:30:01 PM(UTC)
Maytag leaking during spin cycle (Washer Repair)
by red574 4/24/2009 4:43:49 PM(UTC)
Maytag leaking water inside (Refrigerator & Freezer Repair)
by lumpkinp1 10/25/2008 6:48:15 AM(UTC)
