My Maytag refridgerator is leaking water inside -- it appears to be pooling up in the control unit up top. I can feel water inside the part near the back ? A few weeks back I pulled everything out of the freezer - took off the back panel and there wasn't any frost buildup. Appears to be a clog up in the unit inside the fridge -- is this the damper ? How can I fix this ?
sounds as if ur drain line is clogged
youre drain tube may be leaking that is a very cheap simple repair
Seems like my maytag side by side freezer is doing the same thing. Please let me know if the plug or thermostat was you problem. thanks
Just think i fixed my problem, My drain was not frozen but my water tray was full and not letting the water drain from the tube. I think because my fridge is on such a slope that the the water tray was not moving the water where it should have been distributed on the other end of the tray. Pushed the tray up to make it level. Hopefully this works.
