fswartsr
#1 Posted : 14 years ago
fswartsr
The door switch is so sensitive that, as it runs, the microwave stops or, on occasion keeps running but does not heat anything. Is it the latch and if so what particular part can be replaced?
#2 Posted : 14 years ago
Remove the top grille, open the control panel and check the door switches while the door is closed and open.
The problem can be a bad switch, a bad door latch or a bad interlock - #13 on the diagram.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMS1 MICROWAVE HOOD COMBINATION | AppliancePartsPros.com
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 8 months ago
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 about a year ago
Access to microwave door switch (Microwave Repair)
by wbush 12 years ago
