mtbob
#1 Posted : Friday, February 18, 2011 9:58:53 AM(UTC)
mtbob
The fridge is warm and freezer has frost build up on back wall.
I ran the diagnostic test through the control panel and it shows a defrost thermostat short. I also did a forced defrost and the fridge started cooling again. Would this indicate the defrost thermostat is bad or the defrost timer is bad?
Jeff / APP Team
#2 Posted : Friday, February 18, 2011 10:12:28 AM(UTC)
Jeff / APP Team
You can test the thermostat with a multi-meter. It should be closed when it is cold. If open you will need this part.Part number: AP4009073
Guest
#3 Posted : Monday, July 25, 2022 9:18:41 AM(UTC)
Guest
Rank: Guest
United States
I have a similar problem. I've replaced both parts listed. Thoughts?
