The fridge is warm and freezer has frost build up on back wall. I ran the diagnostic test through the control panel and it shows a defrost thermostat short. I also did a forced defrost and the fridge started cooling again. Would this indicate the defrost thermostat is bad or the defrost timer is bad?
You can test the thermostat with a multi-meter. It should be closed when it is cold. If open you will need this part. Part number: AP4009073
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a similar problem. I've replaced both parts listed. Thoughts?
