elmermax
#1 Posted : Tuesday, February 15, 2011 5:32:30 AM(UTC)
elmermax
I just replace the water valve with a new one. The ice maker still runs for an additional 2 or 3 seconds after it is full and should shut off.
Any ideas what I need to do to repair???
Thanks.........:)
Jeff / APP Team
#2 Posted : Tuesday, February 15, 2011 12:51:37 PM(UTC)
Jeff / APP Team
Have you tried to adjust the fill level of the icemaker. To do this you need to remove the cover of the icemaker. The adjustment screw is located on the right side. If you adjust this and still have the same problem. You need to change the module. This is the Part number: AP4359694
Icemaker overfills (Refrigerator & Freezer Repair)
by davebloyd 6/12/2009 8:19:43 AM(UTC)
GE Icemaker Overfills just a little bit (Refrigerator & Freezer Repair)
by rmcardam 3/12/2008 5:27:48 PM(UTC)
