I just replace the water valve with a new one. The ice maker still runs for an additional 2 or 3 seconds after it is full and should shut off.
Any ideas what I need to do to repair???
Thanks.........:)
Have you tried to adjust the fill level of the icemaker. To do this you need to remove the cover of the icemaker. The adjustment screw is located on the right side. If you adjust this and still have the same problem. You need to change the module. This is the Part number: AP4359694
