The display on the control panel showing the time, power setting, etc. is very dim and difficult to read. The switch works fine, it's just very dim. Should I order a new board?
Thank you!
Yes you are correct. If the display is dim then you will need to replace the control board. The correct part number is Part number: AP4262913
. Hope this helps!
Originally Posted by: Jeff / APP Team Yes you are correct. If the display is dim then you will need to replace the control board. The correct part number is AP4262913. Hope this helps! Thank you!
