The display on the control panel showing the time, power setting, etc. is very dim and difficult to read. The switch works fine, it's just very dim. Should I order a new board?
Thank you!
Yes you are correct. If the display is dim then you will need to replace the control board. The correct part number is Part number: AP4262913
. Hope this helps!
Originally Posted by: Jeff / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes you are correct. If the display is dim then you will need to replace the control board. The correct part number is AP4262913. Hope this helps! Thank you!
