Smokedparts
#1 Posted : Friday, December 12, 2008 2:18:49 PM(UTC)
Smokedparts
My dryer was making a very loud noise similar to a pair of tennis shoes clunking around in the dryer.
I replaced the two roller assemblies that were in fact worn and for good measure I installed a new drive belt. Upon reassembly of the dryer and test --I had the same awful noise. From a rotating part standpoint there are not too many things that would cause that kind of noise. Help what else could be the problem?
libertyappl
#2 Posted : Saturday, December 13, 2008 5:42:09 AM(UTC)
libertyappl
Look inside the drum and see if any of the paddles are loose.
Here's the breakdown Model DE512
Nat
Smokedparts
#3 Posted : Saturday, December 13, 2008 6:21:11 AM(UTC)
Smokedparts
I checked for any loose baffles in the dryer drum and they were tight. It is like adding two and two and you keep getting five which you know is wrong.
#4 Posted : Saturday, December 13, 2008 6:23:05 AM(UTC)
When you replaced the rear rollers, did you also replace/check the shafts?
Check that the idler is OK
Check the drum where the rollers ride, for a split or there may be something stuck to it.
Check that the blower wheel is tight onto the motor shaft and nothing has fallen into it.
Check the felt seals if they are not lapped correctly they can grab onto a seam as the drum rotates. Not sure if this applies to your unit
Smokedparts
#5 Posted : Saturday, December 13, 2008 6:54:19 AM(UTC)
Smokedparts
The shafts were not replaced but they appeard to be Ok.
I did clean the drum as there was a sticky residue around the drum at the end towards the back of the dryer and it was not uniform.
The felt around the two end pieces that capture the drum was not uniform and bent over but given the wear pattern it appeared it had been that way for a long time.
I looked over the motor and did not see anything there but I may need to revisit that.
What I did not mention in my original post is that one of the umpteen times that I have reassembled the dryer the belt slipped off but I did not know that. When I ran the dryer for a test with the front door off the drum was not moving but the noise was there. I might be fixing the wrong problem.
Thanks for your suggestions.
#6 Posted : Saturday, December 13, 2008 7:09:36 AM(UTC)
Yep I would say you have a motor or hopefully a blower problem.
Here is something to check on the motor
http://www.applianceaid.com/wp-motors.html
SublimeMasterJW
#7 Posted : Saturday, December 13, 2008 8:24:26 AM(UTC)
SublimeMasterJW
The drum rides on slides in front. Did you check them?
