RICK21770
#1 Posted : Sunday, February 13, 2011 11:26:35 AM(UTC)
RICK21770
I have a kitchen aid dishwasher that will fill with water just below the heater element. The heater element gets hot but the washer stalls and doesn't go to the next step. In the end it gives he a flash code of seven. In the owners sheet it refers you to the heating element. I removed it and tested it, 15 ohms it was in spec. I ran diagnostic to clear the code and it does it again. At this point I am lost
#2 Posted : Monday, February 14, 2011 3:26:28 AM(UTC)
Replacement parts for WHIRLPOOL KUDS01FLSS6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Since you know that 7 flashes points to a heating problem you probably have the tech sheet but just in case you do not see the a6ttachment.
The following may be helpful
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
You will see that the hi-limit thermostat and one of the door switches are also in the heater circuit so you will have to check them. If you are sure that it is heating up then both the above are OK.
I would check the thermistor.
Check that the water temperature is at least 120 degrees F.
File Attachment(s):
KUDS01FL.pdf (171kb) downloaded 11 time(s).
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Kitchen Aid Dishwasher - KUDS25SHBT1 (Dishwasher Repair)
by Karen M 10/19/2022 10:03:13 AM(UTC)
Kitchen Aid Dishwasher Upper Spray Arm (Dishwasher Repair)
by Guest 1/13/2022 12:58:02 PM(UTC)
Kitchen Aid Dishwasher KUPC10FxSS5 Di (Dishwasher Repair)
by Andrew Glass 9/27/2021 11:37:55 AM(UTC)
Kitchen aid dishwasher KUDS01FLSS5 - top rack doesn't get wet and soap residue (Dishwasher Repair)
by Joe D Raleigh 10/13/2019 3:25:49 PM(UTC)
Kitchen Aid Dishwasher Screech (Dishwasher Repair)
by mark.stacy@emc.com 11/5/2018 6:45:56 PM(UTC)
Kitchen Aid Dishwasher Blinking Lights (Dishwasher Repair)
by T/Y4HELP 8/7/2016 5:20:39 AM(UTC)
No lights on Kitchen aid dishwasher (Dishwasher Repair)
by Gschimma 12/22/2015 7:02:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
kitchen aid dishwasher drain motor will not run (Dishwasher Repair)
by phantomjet 4/22/2015 8:17:13 PM(UTC)
kitchen aid dishwasher (Dishwasher Repair)
by jacquesaccount 8/21/2014 8:15:31 AM(UTC)
Kitchen Aid dishwasher stopped working (Dishwasher Repair)
by acillatem 6/15/2014 6:12:42 PM(UTC)
Kitchen Aid dishwasher doesn't drain completely (Dishwasher Repair)
by rgjhnsn 5/31/2014 5:57:43 PM(UTC)
Kitchen Aid Dishwasher won't start (Dishwasher Repair)
by waveraider 1/30/2014 9:00:51 PM(UTC)
Kitchen Aid Dishwasher: Blinking Lights, Unfinished Cycle General Malaise (Dishwasher Repair)
by 3Zero 10/24/2013 4:57:00 PM(UTC)
