ANiforos
#1 Posted : Friday, December 12, 2008 8:08:30 AM(UTC)
ANiforos
I just posted a question about my fridg portion not cooling and I forgot to ask another question.
I am anticipating maybe having to change the defrost thermostat also. There are two wires coming from the defrost thermostat.....an orange one that has a little spade connection that plugs into the defrost element. The other wire, a yellow one, goes into a cloth covered bundle of wires that go to the plug for the icemaker. It doesn't look like that yellow one has a connection on the end of it. If I replace the defrost thermostat, do I just cut the wire, and splice it together and tape it with electrical tape? Or is there some type of moisture proof connections I can crimp onto the ends where I cut it?
Thanks again.
Alex
abadfish66
#2 Posted : Friday, December 12, 2008 8:17:48 AM(UTC)
abadfish66
Splice it. I would use a bell connector then fill the end with some silicone to keep the moisture out.
Replacing Defrost thermostat on (GE) Kenmore (Refrigerator & Freezer Repair)
by AUricle 7/14/2016 9:05:45 PM(UTC)
