I have a Whirlpool Dryer that was recently moved from one location to another. After set-up and three loads later, when I opened the door of the dryer, the drum kept turning. The dryer light inside the unit is also not working. I found my way to the door switch. Now I can't seem to get the thing unplugged to replace it? Is there a trick for that? Thanks in advance!
A small screwdriver to release the safty latch on the plug helps remove it.
Nat
