widget925
#1 Posted : Friday, February 11, 2011 12:10:37 PM(UTC)
widget925
Is there any way to purchase the impeller only? Motor is fine. I had a "buzzing" noise while the washer was in a wash cycle, but no noise while draining. Turns out, the chopper ate itself. This caused the end of the impeller to get a little rounded out. Hate to have to buy a whole pump assembly for a little plastic part.
#2 Posted : Sunday, February 13, 2011 4:18:23 AM(UTC)
Here is what I did, I looked at other models that use this pump (KUDP01DLBS7).
It showed the impeller/seal kit (Item 22 in Section 8).
Unfortunately it also shows it as "out of stock" which often translates into obsolete.
You will have to call to find out the availability.
Also I am not 100% sure it will fit so it is a gamble.
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
