The door frame to my microwave is cracking and is broken in a few spots around the handle. I purchased the replacement door from Sears. I have tried to take the door assembly apart by removing the three screws, but I have no idea how to get the outer door assembly off... HELP!!!
Thank you.:p
Corinne, You will probably need to take the MW down and remove the outer case to access the hinge for the door.
Nat
I just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. I certainly am no expert, but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great. Good luck! Tyler Originally Posted by: Corinne Sayles  The door frame to my microwave is cracking and is broken in a few spots around the handle. I purchased the replacement door from Sears. I have tried to take the door assembly apart by removing the three screws, but I have no idea how to get the outer door assembly off... HELP!!!
Thank you.:p
