aubbie
#1 Posted : Wednesday, December 10, 2008 4:58:04 PM(UTC)
aubbie
Oven temp display goes up very quickly (5 degrees every 8 seconds) then when it reaches preset temp, actual oven temp is 100 degrees cooler. Replaced thermositor and bake element. any thoughts?
libertyappl
#2 Posted : Wednesday, December 10, 2008 5:00:45 PM(UTC)
libertyappl
Did you check the oven sensor?
Here's your breakdown. Model JKP13GP3BG
Nat
aubbie
#3 Posted : Wednesday, December 10, 2008 6:03:50 PM(UTC)
aubbie
yes-put a new one in and bake element. Calibrated temp by+35 degrees. Still seems to be 25 degrees low. Probably looking at the bad board no longer made
libertyappl
#4 Posted : Thursday, December 11, 2008 8:53:14 AM(UTC)
libertyappl
You can contact GEneral Time Repairs at 712-792-1248 with the number on the tag of the control board itself for possible repair. I've had them rebuild one for me that was no longer available and they did a great job.
Their website is generaltimerepairs dot com.
Nat
Guest (4)
