Oven temp display goes up very quickly (5 degrees every 8 seconds) then when it reaches preset temp, actual oven temp is 100 degrees cooler. Replaced thermositor and bake element. any thoughts?
yes-put a new one in and bake element. Calibrated temp by+35 degrees. Still seems to be 25 degrees low. Probably looking at the bad board no longer made
You can contact GEneral Time Repairs at 712-792-1248 with the number on the tag of the control board itself for possible repair. I've had them rebuild one for me that was no longer available and they did a great job. Their website is generaltimerepairs dot com. Nat
