bschroat, remove the rear panel and locate the wires going to the bake element.
pitdaddy, Yes the broiler has a separate ignitor, so it can still light.
Nat
Replaced the ignitor and the oven still won't heat. What next? Need to get it running for christmas dinner.
pitdaddy, Check your burner bar, make sure it's clean inside.
Nat
Originally Posted by: libertyappl pitdaddy, Check your burner bar, make sure it's clean inside.
Nat Looks ok. is there a problem with the thermostat or switch?
