The oven heats and has a flame on broil but dosen't heat on bake. What might I look for to fix this problem?
I have a tappan model tef361esc its is only 3 years old and just the other day we went to bake in the oven and it would not heat up to the set temp. what could be wrong with my oven.:confused:
bschroat, Since yours is an electric oven it could be a couple of things. Did it heat at all?
Nat
Will this work on the hotpoint model I have? It is a gas oven.
Originally Posted by: libertyappl bschroat, Since yours is an electric oven it could be a couple of things. Did it heat at all?
Nat it got warm but never got to the temp set. we did try the broil and that worked barb
in never got to the temp we wanted. but we did try the broil and that worked.
ppitdaddy, yes that will work Hotpoint is made by GE
bschroat, You need to check the wires and voltage going to the bake element.
Nat
Originally Posted by: libertyappl ppitdaddy, yes that will work Hotpoint is made by GE
Nat where would that be?
Will the broiler still light if the bake ignitor doesn't?
