The right front element part AP2634743 has failed on this cooktop and I ordered the new element from APP. Although the part photos on the website show the calibration instruction sheet no such sheet was included when I received the part. Customer service says they would have sent anything that came in the box. Does any one have a copy or PDF of the calibration instructions?
Tom Martin
Well, I did not get any answers from the pros here, so I found out myself. The full wiring diagram, troubleshooting, and calibration instructions are on a sheet inside the cooktop. You can access it once you get the ceramic top off. I confirmed the failed temp sensor with my multimeter. The element replacement was straightforward, and the calibration of all 5 inductive sensors was also straightforward using the instructions. Calibration took about one minute. Elsewhere on this board one of the pros states that calibration can only be done by a GE technician and is extremely complicated. Incorrect.:)
