mriley44
#1 Posted : Tuesday, December 9, 2008 2:02:03 PM(UTC)
mriley44
There is slow water leak towards left front. There are no leaks from hoses in back of machine. There is sizable puddle after one load. I haven't troubleshooted yet. Does the top of machine lift up by prying it or are there screws? Is repair manual available? Your thoughts on source of leak are appreciated. Thanks.
Michael1061
#2 Posted : Monday, June 29, 2009 8:54:52 AM(UTC)
Michael1061
I have a Maytag Neptune front load that developed a leak in the front and it turned out that the rubber collar thing had developed some splits in the rubber which allowed water to leak out. I think the part costs about $65. I had mine repaired and it ran about $200. Now I make the repairs and I can't fix my current problem of the spin cycle not working I will junk it and go buy a Kenmore.
#3 Posted : Monday, June 29, 2009 11:41:08 AM(UTC)
Michael,
Before you buy a Kenmore washer make sure who made it. It can be another Neptune or even worse - it can be made by LG or Samsung.
I just bought the washer for myself. It's made by Whirlpool, a classic top load model, without any serious computers and it works as a charm. I paid for it less than $500!
Guest (4)
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Maytag Washer leaks (Washer Repair)
by A00446849 2/20/2012 9:31:31 AM(UTC)
Maytag Washer leaks on side of drain hose (Washer Repair)
by della 12/17/2011 10:34:04 PM(UTC)
maytag washer leaks (Washer Repair)
by kramler92 12/7/2011 4:47:43 PM(UTC)
Maytag Washer leaks at bottom (Washer Repair)
by ronf 10/23/2010 6:07:28 AM(UTC)
Maytag washer leaks on the bottoom (Washer Repair)
by Bummer plumber 9/9/2010 7:56:24 AM(UTC)
Maytag Washer Leaks (Washer Repair)
by badodd 8/5/2010 5:15:33 PM(UTC)
by fabian g 7/1/2010 4:53:31 PM(UTC)
Maytag washer leaks as soon as its filling (Washer Repair)
by TonyCud01 4/3/2010 8:21:11 AM(UTC)
Maytag Washer Leaks at Drain Cycle (Washer Repair)
by ganzhimself 12/13/2009 6:52:55 PM(UTC)
Maytag washer leaks (Washer Repair)
by smcneil 5/10/2008 11:37:29 AM(UTC)
My Maytag washer leaks onto floor (Washer Repair)
by mbrew5335 12/26/2007 12:21:13 PM(UTC)
