rick2336
#1 Posted : 14 years ago
rick2336
My washer was leaking onto the floor which at first we thought was an intermittent problem. It began to leak more and more so I took it outside and took the front off and watched it run through a cycle. I suspect it is the tub seal because I see water dripping down from tub onto the shaft of the transmission. I haven't taken it apart yet but does this sound like the right part to replace? While its apart should I replace anything else like washer tub bearing, split ring etc?
Also this is the first time I have taken this unit apart. Is the entire transmission housing supposed to spin? I noticed slight movement during agitation but on the spin cycle it was spinning as fast as the tub. Just wanted to verify this was normal! Thanks for any assistance!!!
Rick
applianceman
#2 Posted : 14 years ago
applianceman
First off yes it is normal for the transmission to spin during the spin cycle.
The tub seal will more that likely take care of the leak and this may be all you have to do to make the repair. However almost every time I have seen a tub seal leaking the washer has been very noisy during spin. The only way to repair the noise problem is to replace the transmission. If it isn’t noisy or you can put up with the noise it is ok just to replace the tub seal.
[FONT='Times New Roman']This page should help you GE Washer Disassembly Guide[/FONT]
rick2336
#3 Posted : 14 years ago
rick2336
Thank you very much. I will follow up after the repair!
GE washer leaking, stripping showing under agitator (Washer Repair)
by JasonSolaris 11 years ago
Top Load GE Washer leaking from Side Front Right... GTWN4950L0WS (Washer Repair)
by justin954 12 years ago
GE Washer Leaking When Off (Washer Repair)
by texaus007 12 years ago
GE Washer Leaking Left Rear (Washer Repair)
by tbilbrey 13 years ago
GE Washer Leaking & Now Not Draining (Washer Repair)
by Nash123 14 years ago
GE washer leaking under the agitator area (Washer Repair)
by handyman Glenn 15 years ago
GE washer leaking (Washer Repair)
by jstorm 15 years ago
GE washer leaking (General Talk)
by greenway 16 years ago
Norge Washer leaking and doesn't drain (Washer Repair)
by aesp 17 years ago
GE washer leaking water (Washer Repair)
by lena40356 17 years ago
