refrigator to warm ,frezer works fine.
someone said that it may be some kind of fan
:( :( Originally Posted by: CHERYL ATCHLEY someone said that it may be some kind of fan i would like to know if anyone could help.
Groups ready for retrieval: Registered
Is frz. ok? You may have a problem with cool air pass or damper frozen. Put your hand under the air duct, no air? chck the apening of the air duct.
Need model # to check. I would remove freezer panel and check for frozen evaporator. Id frozen,I would turn the defrost timer till compressor stops and check the defrost heater in freezer. If it heats up, replace defrost timer, if not replace defrost thermostat. You will have to post model # to order parts from this site.
