glennkeenan
#1 Posted : Wednesday, February 2, 2011 3:22:55 PM(UTC)
glennkeenan
everything else works on dryer when i hit start switch nothing works
#2 Posted : Thursday, February 3, 2011 1:35:31 AM(UTC)
Replacement parts for KENMORE 11064942300 | AppliancePartsPros.com
Not quite sure I understand what "everything works" means.
If everything worked the motor would run.
If you mean that the interior light works and the timer works but the motor does not then the most likely culprit is the thermal fuse (first Item in the parts listing) mounted on the blower assembly.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as this are the most common causes of it blowing.
Whirlpool WDTA50SAHZ0 no start, flashing lights (Dishwasher Repair)
by lewist57 9/15/2023 2:30:03 PM(UTC)
Frigidaire Affinity NO START, the light is not on when the door is open (Dryer Repair)
by Guest 3/13/2022 9:02:49 PM(UTC)
Whirlpool Duet ghw9300pw4 has power but no start (Washer Repair)
by 5150 2/18/2022 7:16:37 PM(UTC)
Dryer Buzz and no start (Dryer Repair)
by rsangus 2/3/2019 10:11:41 AM(UTC)
Frigidaire Dryer beeps 3 times - no start (Dryer Repair)
by boriska13 6/27/2017 8:59:46 PM(UTC)
Click no start (Dryer Repair)
by leftymurphy 6/1/2017 3:24:01 PM(UTC)
kitchenaid dishwasher no start (Dishwasher Repair)
by jr1397 3/11/2017 7:52:29 AM(UTC)
Roper Washer no Start (Washer Repair)
by bellmd 1/21/2017 6:08:14 AM(UTC)
No Start (Dryer Repair)
by jjuly 11/21/2016 8:11:37 AM(UTC)
Frigidaire Dryer No start (Dryer Repair)
by Cable Guy 4/1/2016 5:47:49 PM(UTC)
Inglis Electric Dryer itermittent no start (Washer Repair)
by Tom Colins 12/5/2015 4:45:55 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
dryer makes noise but no start (Dryer Repair)
by joe7875 7/23/2013 4:26:05 PM(UTC)
maytag centennial no Start (Washer Repair)
by tjspeed25 3/18/2013 10:59:46 AM(UTC)
Gas Dryer buzzes & no start on occasion. (Dryer Repair)
by techman_hou 5/26/2012 4:03:32 PM(UTC)
