rick perez
#1 Posted : Tuesday, February 1, 2011 5:50:56 PM(UTC)
rick perez
My lady kenmore ultra fabric dryer won't turn on. Is there a reset button somewhere?
#2 Posted : Wednesday, February 2, 2011 3:51:30 AM(UTC)
A model number may help others help you
Model Number Locator
There is no reset button but many units have a thermal fuse mounted on the blower assembly.
If this fuse blows it kills power to the motor.
The most common cause of it going is a clogged or malfunctioning vent system.
The first thing to check is power going to the unit.
If it has a drum light and the light still works then it has power to at least start the motor.
Try flipping the breaker off/on slowly a couple times.
kayakcrzy
#3 Posted : Wednesday, February 2, 2011 4:47:28 AM(UTC)
kayakcrzy
There is a thermal fuse in the back of the dryer. You have to unplug the dryer, and then take the big back panel off, and there will be a thin white part, about an inch and a half long, by a half inch wide. It will have two wires coming to it. That is usually the culprit. Also, check the door switch. Open the door, and there will be a thin metal piece, push it in, and be sure iyou hear a click. Sometimes those metal pieces break, and the dryer won't come on at all.. Tom ApplianceEducator.com
