shadyinc76
#1 Posted : Sunday, December 7, 2008 3:00:57 PM(UTC)
shadyinc76
drive belt needs to be replaced, help if you can.
kayakcrzy
#2 Posted : Monday, December 8, 2008 4:29:18 AM(UTC)
kayakcrzy
What you have to do is get the top up. Open the door of the dryer, and then look under the top in the front, and there will be a few screws to take out, that will lift up the top. Then you need to take the front off. Now of course we are starting this with the dryer unplugged. Look inside the front panel, up top on the left and right side, and there will be a 5/16s screw. Remove them, and then take the wires off the door switch, and remember where they go. Then get your new belt and wrap it around the drum, rib side down, and then go to the back side of the dryer, and take off the rear access panel, and then put the belt on. Also clean out the blower housing on the blower housing on the front, while you are there. Let me know how it goes. Tom
Drive Belt Replacement (Washer Repair)
by mzulkoski 6/27/2012 12:49:20 PM(UTC)
Drive Belt Replacement (Dishwasher Repair)
by TerryNi 3/7/2012 1:18:48 PM(UTC)
drive belt replacement (Washer Repair)
by RodE 1/22/2012 1:16:04 PM(UTC)
Maytag Atlantis Drive Belt Replacement ??? (Washer Repair)
by oaktree 9/1/2011 1:44:35 PM(UTC)
Drive belt Replacement (Washer Repair)
by gary2kb 3/13/2011 6:19:51 AM(UTC)
Drive belt replacement (Washer Repair)
by Ron C 12/3/2010 4:13:02 AM(UTC)
Whirlpool le58ooxkwo drive belt replacement (Dryer Repair)
by oldguy 8/23/2010 2:04:21 PM(UTC)
by JDS1044 4/24/2010 2:54:16 PM(UTC)
by Mikeolaw 8/8/2008 3:51:00 PM(UTC)
