This range heats for about 10 minutes then stops heating. The oven calls for gas then the power stops to the gas valve. Sometimes it will light for 1 to 3 seconds then fail. It will continue to try to relight. I tested the saftey thermostat and it isn't failing there.There is no fault code that comes up and I couldn't find a schematic Someone came out and was on the phone with Whirlpool and replaced the wire harness. Thanks, Pipemaster17
Can any one tell me where I can get a schematic? for this?
Can anyone tell me where I can get a schematic?
Does any one know the ohm reading should be on the sensor for this unit?
