pipemaster17
#1 Posted : Sunday, January 30, 2011 1:45:32 PM(UTC)
pipemaster17
This range heats for about 10 minutes then stops heating. The oven calls for gas then the power stops to the gas valve. Sometimes it will light for 1 to 3 seconds then fail. It will continue to try to relight. I tested the saftey thermostat and it isn't failing there.There is no fault code that comes up and I couldn't find a schematic Someone came out and was on the phone with Whirlpool and replaced the wire harness.
Thanks,
Pipemaster17
pipemaster17
#2 Posted : Sunday, January 30, 2011 3:35:38 PM(UTC)
pipemaster17
Can any one tell me where I can get a schematic? for this?
pipemaster17
#3 Posted : Sunday, January 30, 2011 3:42:04 PM(UTC)
pipemaster17
Can anyone tell me where I can get a schematic?
pipemaster17
#4 Posted : Monday, January 31, 2011 3:28:29 PM(UTC)
pipemaster17
Does any one know the ohm reading should be on the sensor for this unit?
