My Dryer will lite up for about 2 mins. then the flame goes out then about 2 mins later it will try to light up but no flame comes up. Also the dial will not advance so it will run cold untell I shut it off. the time dry cycle will advance but doesn't dry either.:confused:
The coil is what gives the signal for the gas to go on. Replace coil part # AP3094251 In auto mode when the heat is on the timer will advance. since there is not heat it won't complete the run.
Thank You I will do that.
