besa
#1 Posted : Saturday, December 6, 2008 5:44:35 PM(UTC)
besa
My Dryer will lite up for about 2 mins. then the flame goes out then about 2 mins later it will try to light up but no flame comes up.
Also the dial will not advance so it will run cold untell I shut it off.
the time dry cycle will advance but doesn't dry either.:confused:
Eddie365
#2 Posted : Saturday, December 6, 2008 6:21:50 PM(UTC)
Eddie365
The coil is what gives the signal for the gas to go on.
Replace coil part # AP3094251
In auto mode when the heat is on the timer will advance.
since there is not heat it won't complete the run.
besa
#3 Posted : Sunday, December 7, 2008 11:10:55 AM(UTC)
besa
Thank You I will do that.
