press start and hold hear timer hum as if it has a motor running and click electric motor does not start where should i start trouble shooting checked pig tail ,its good ,the plug wire thanks all dryer door parts are ok switch not tested yet.
Here are your parts, includes a wiring diagram. Replacement parts for FRIGIDAIRE FDE648GFS0 Frg(v1) / Dryer | AppliancePartsPros.com[COLOR="DarkRed"]checked pig tail ,its good [/COLOR] Sorry but I do nor understand what you mean. If the interior light works then you know power (L1 to Neutral) for the motor is OK.. I would check the thermal limiter (fuse) (Item 36 in Section1) first. Unplug the unit. Remove one wire from the fuse and check it with a meter. Should be 0 ohms. If it is blown then replace it and check/clean your vent suystem as this is the most common cause of it going. Not a bad idea to also clean/check your blower wheel. Next would be the door switch and then the start switch. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Here are your parts, includes a wiring diagram. Replacement parts for FRIGIDAIRE FDE648GFS0 Frg(v1) / Dryer | AppliancePartsPros.comchecked pig tail ,its good Sorry but I do nor understand what you mean. If the interior light works then you know power (L1 to Neutral) for the motor is OK.. I would check the thermal limiter (fuse) (Item 36 in Section1) first. Unplug the unit. Remove one wire from the fuse and check it with a meter. Should be 0 ohms. If it is blown then replace it and check/clean your vent suystem as this is the most common cause of it going. Not a bad idea to also clean/check your blower wheel. Next would be the door switch and then the start switch. thanks it was the thermal limiter aka fuse got 0 ohms reading jumper out fuse dryer runs normal blower blows good good heat gonna run this way entil new parts come in
Replace the fuse ASAP as this is a critical safety device.
If you have a heater fault running without the fuse could cause a lint fire which can turn into a house fire. |
